I am designing a system with the ADS4245. My requirement being a 14bit,dual channel I/P and a max of 125MSPS. I understand that going higher without the capabilty to program or select an output sampling rate would be a disaster. Hence-forth I went with the ADS4245.
With the requisite parameters are entered, the TI website recommends the ADS4245 But, the data sheet shows the output as LVDS.
How can then this serve my purpose please ? I am attaching the image of that chip (and the LVDS info). Wouldnt LVDS be useless as in effect it is a 7bit differential output where as I am needing 14 bit output.
What is the difference between a normal 14bit ADC output and an LVDS output ? I merely wanted to confirm that this would be of no use to me due to its LVDS capability.
