Problem: Find \$I_{1}, I_{2}, I_{4}, I_{6}\$ using Kirchoff's rule
\$E\$ is the voltage source of 8 Volts and \$I_{general}\$ is the current source of 3 Amps.
My steps:
I think there are 5 branches and 3 nodes and also 3 independent loops. So the number of needed equations = \$3-1 = 2\$ Using this I got equations:
For node 1: \$-I_{6}+I_{1}+I_{general}\$
For node 3: \$-I_{4}-I_{1}+I_{2}+I_{6}\$
Also I think there are 2 loops needed for equations: the bottom rectangle and the left one:
Loop1: \$1-3-1\$
Loop2: \$3-2-3\$
So we heave 2 more equations:
1) \$I_{1}R_{1}+I_{6}R_{6}=0\$
2) \$I_{2}R_{2}+I_{4}R_{4}+I_{2}R_{3}=E\$
So we got system of equations to solve: \begin{cases} -I_{6}+I_{1}+I_{general}=0 \\ -I_{4}-I_{1}+I_{2}+I_{6}=0 \\ I_{1}R_{1}+I_{6}R_{6}=0 \\ I_{2}R_{2}+I_{4}R_{4}+I_{2}R_{3}=E \end{cases}
Solving which, gives this result:
$$I_{1}=-2.571\\ I_{2}=-1.244\\ I_{4}=1.755\\ I_{6}=0.42$$
Question: Is there anything that I did right? I can get 0 in product of sum of I's but for that I need to change some signs a bit. Did I solve this correctly or there is something wrong in it or completely wrong?
