This datasheet has a table (see Table 3-2) detailing latencies for the two parts of a 10GB Ethernet PHY, namely the PCS (Physical Coding Sublayer) and PMA (Physical Medium Attachment Sublayer).
While the latency for the PCS is unambiguously defined in clock cycles (for a clock running at 156.25 MHz), the latency for the PMA is given in "UI" (Unit Interval, I assume).
What is the UI in this context? Is it different from a clock cycle?
