Some datasheets define parasitic/parallel capacitance for a diode. MA4E2532 datasheet even list SPICE Cjpar
parameter.
But the LTspice D
model lacks this parameter. An inductor L
model has Cpar
parameter but diodes don't. Am I missing something? Is this parameter has a different name or is it inherently useless to define and model it? When I manually add parallel capacitor to a diode it drastically change the results on high frequency.
Cjo
(there's alsoCjsw
, but that's not what you're after)? Even if it isn't, that's what you should use (see the help inLTspice > Circuit Elements > D. Diode
, the 2nd table. \$\endgroup\$Cjo
is a different parameter which is also listed in a different column in the table.Cjsw
is described as a Sidewall Cjo, is it the other name forCjpar
parameter in the table from datasheet? \$\endgroup\$
