I have been searching everywhere online on how to make this circuit. I found out I can make NAND gates using I2L and connect them together to make a T flip flop , but this is very impractical since I will end up using 48 transistors.
I found a circuit for a negative edge triggered T flip flop using Bistable multivibrators .
I connected the circuit in Multisim and tested it , and it gave me the correct output for a T flip flop.
enter image description here enter image description here
I figured that in order to make it I2L I have to replace every resistor in the circuit with a pnp bjt transistor ( 2n3906) as a current source and it should work, but it ended up giving me a really weird output.
I also came across a different circuit from 1980 of a "Triggerable flip flop" using I2L , but it used multi-collector npn bjt transistors and I don't know to make these. (https://patents.google.com/patent/EP0032154A1/en)
Please help me either fix the circuit I made so it works and tell me how to make a multi-collector npn bjt.
Thank you
  • \$\begingroup\$ For most purposes, a multi-collector transistor is equivalent to two (or more) transistors with their bases and emitters connected in parallel. The transistors need to be well-matched for best results. \$\endgroup\$
    – Dave Tweed
    Commented May 5, 2021 at 0:21
  • \$\begingroup\$ What’s the fascination with 50 yr old technology replaced the following year by TTL , see p3 ti.com/lit/ds/sdls119/… \$\endgroup\$
    – D.A.S.
    Commented May 5, 2021 at 0:36
  • \$\begingroup\$ Its a project I need to finish, I really don't care about or like the technology , for some reason the professor decided to assign a project to me where I have to make a simple component using an obsolete technology. \$\endgroup\$
    – DeadSlayer
    Commented May 5, 2021 at 0:52
You cannot connect the emitter of a PNP transistor to +5V and the base to ground. That will burn out the transistor. Instead, you must include a resistor, either between base and ground, or between the emitter and +5V. I have only seen the later today, when researching I2L logic. (Actually it seems pretty interesting).
Although I don't have a circuit for a edge-triggered D-Flip-Flop, I do have an I2L circuit for an SR-latch. That should give you implementation ideas.
[That part of the circuit that includes the relays and everything "below" the relays is there only for testing purposes. It is not part of the I2L SR-latch.]
Notice that there is a resistor between Vcc and the PNP transistor emitters. Changing that resistor will change the current consumed by the SR-latch.
The output of the circuit is:
Hope this get's you on your way!
I was able to fix the circuit I posted above by simply changing the value of the capacitors from 1uf to 1nf
Though if I added any value of resistance ( to the VCC) , it completely destroys the output.
What Can I do about this ?
  • \$\begingroup\$ Maybe I can decrease the vcc ? \$\endgroup\$
    – DeadSlayer
    Commented May 5, 2021 at 8:51
  • \$\begingroup\$ Per my answer, you cannot connect the emitter of a PNP transistor to +5V and the base to ground. That will burn out the transistor. I am referring specifically to Q3 and Q4 in your schematic. Your simulator may not complain, real transistors will. Check the base current in those transistors with your simulator. \$\endgroup\$ Commented May 5, 2021 at 11:12
  • \$\begingroup\$ 404 mA, which will probably burn it \$\endgroup\$
    – DeadSlayer
    Commented May 5, 2021 at 11:35
