I am laying out my PCB and I would like to include this power connector in the layout. I am unable to identify the connector based on the its locking ability and layout. It could even be a common one and I am just missing something.
1\$\begingroup\$ Do you want to purchase a connector, or just need a footprint to place on the PC board? If you just need a footprint, it will be much easier and faster to make the footprint yourself than to try to find a ready-made footprint. If you do any amount of PC layout, you will need to make some of your own footprints, so you may as well learn how now. \$\endgroup\$– Peter BennettCommented Dec 19, 2013 at 23:41
\$\begingroup\$ I am trying to identiy the connector so I can pinpoint a datasheet with exact measurements to use if avaliable. \$\endgroup\$– user651933Commented Dec 21, 2013 at 0:53
Add a comment
1 Answer
Can you use this connector for your application?
http://www.digikey.com/product-detail/en/0428192223/WM9796-ND/3310025
The power connector in your photo looks a lot like the ATX series power connectors.
