I am trying to write a testbench for a 16-bit RISC processor using verilog in Xilinx. I have the following modules:
- TOP
-datapath
-instruction_fetch
-program_counter
-instruction_memory
-instruction_register
-MUX21
-alu
-MUX41
-general_purpose_reg
-data_memory
-control_unit
My question is : To get this to work do i need to create just one test bench for the 'TOP' module and have '$display' statements for each module inside it?
FOR EXAMPLE, if i have to display output of the alu module then should I have the display statement in the test bench for TOP?
module top_test;
// Inputs
reg clk;
reg rst;
reg start;
// Outputs
wire [4:0] PS;
wire [3:0] opcode;
wire [15:0] PC;
wire [15:0] IM_instr;
wire [15:0] IR_instr;
wire [14:0] CV;
wire [15:0] R1_reg;
wire [15:0] R2_reg;
wire [15:0] R3_reg;
wire [15:0] R4_reg;
wire [15:0] R5_reg;
wire [15:0] R6_reg;
wire [15:0] R7_reg;
wire [15:0] R8_reg;
wire Z;
wire [15:0] A_ALU;
wire [15:0] B_ALU;
// Instantiate the Unit Under Test (UUT)
TOP uut (
.clk(clk),
.rst(rst),
.start(start),
.PS(PS),
.opcode(opcode),
.PC(PC),
.IM_instr(IM_instr),
.IR_instr(IR_instr),
.CV(CV),
.R1_reg(R1_reg),
.R2_reg(R2_reg),
.R3_reg(R3_reg),
.R4_reg(R4_reg),
.R5_reg(R5_reg),
.R6_reg(R6_reg),
.R7_reg(R7_reg),
.R8_reg(R8_reg),
.Z(Z),
.A_ALU(A_ALU),
.B_ALU(B_ALU)
initial begin
// Initialize Inputs
clk = 0;
rst = 0;
start = 0;
// Wait 100 ns for global reset to finish
#100 ;
rst = 1;
// $display($time, " alumod A_in=%b,B_in=%b,ALU_out=%b", A_in, B_in, ALU_out);
end
always
begin
#5 clk = !clk;
end
endmodule
alu module code :
module alumod(clk,rst,load_SR,ALU_opcode,A_in,B_in,ALU_out,data,carry,Z);
input clk,rst;
input [15:0] A_in,B_in;
input [2:0] ALU_opcode;
input load_SR;
output [16:0] ALU_out;
output [15:0] data;
output carry, Z;
reg [16:0] ALU_out;
reg Z;
always@(ALU_opcode or A_in or B_in)
case(ALU_opcode[2:0])
3'b000: ALU_out = A_in + B_in;
3'b001: ALU_out = A_in - B_in;
3'b010: ALU_out = {{16{A_in[15]}},A_in} >> B_in; //ARITHMETIC
3'b011: ALU_out = A_in << B_in; //LOGICAL LEFT SHIFT
3'b100: ALU_out = A_in >> B_in; //LOGICAL RIGHT SHIFT
3'b101: if (A_in < B_in) //SLT
ALU_out = 1;
else
ALU_out = 0;
3'b110: ALU_out = ~A_in; //INV
//'b111: HAMMING DISTANCE
//default: alu_out = ;
endcase
// Z REGISTER MODULE
always@(posedge clk or posedge rst)
if(rst)
Z <= 1'b0;
else if(load_SR)
Z <= (data == 0);
else
Z <= Z;
assign data = ALU_out[15:0];
assign carry = ALU_out[16];
endmodule
why you are using ALU_out in the top_test module? it's not declared there. you have to put '$display' inside the module if the pin isn't in the scope of top_test \$\endgroup\$
