Arithmetic example Hardware example
I am having trouble working with OLA(online arithmetic addition) radix 2 SD(signed digit) addition MSDF(most significant digit first).
If I have an 8 bits range unsigned number and a redundant and symmetric set of \$\left\{ {-1, 0, +1}\right\}\$ with the following table:
+1 ---> 01
 0 ---> 00
 0 ---> 11
-1 ---> 10
If I want to make \$a-b=c\$, I do not understand how the operation of \$a-b\$ is performed in binary.
If we have \$25-10=15\$,
$$25_{10}=0001 1001_2$$ $$10_{10}=0000 1010_2$$
If we map each two consecutive digits to the those in the table, how do I perform the computation so that I could implement it in hardware?
  • \$\begingroup\$ Why is 0 defined twice? 11 should be 3. \$\endgroup\$
    – kolosy
    Commented Sep 18, 2014 at 13:11
  • \$\begingroup\$ In 2's complement, 0b11 for a 2-bit number is -1. \$\endgroup\$ Commented Sep 18, 2014 at 13:14
    \$\begingroup\$ Perhaps you could clarify/get rid of the abbreviations (although others might know them) \$\endgroup\$
    – Xcodo
    Commented Sep 18, 2014 at 13:16
  • \$\begingroup\$ I would say it is impossible because the mapping is not injective. \$\endgroup\$
    – venny
    Commented Sep 18, 2014 at 13:57
  • \$\begingroup\$ @kolosy : 0 is not defined twice. Zero is either +0-0 or +1-1 \$\endgroup\$
    – Grabul
    Commented Sep 18, 2014 at 20:29
In carry-save/borrow save arithmetics, each binary position is represented as two bits. Numbers can have several possible representations.
+25 = P=11001 / N=00000
-10 = P=00000 / N=01010
The result is simply : +25-10 : P= 11001 / N=01010
P=1, N=1 combinations can be simplified to P=0, N=0.
So : +25-10 : P= 10001 / N=00010
You can convert to a traditional two's complement representation by doing the actual subtraction : 10001 - 00010 = 1111 = 15
For a simple substraction, it does not make any sense. The whole purpose of this mess is that you can do iterative additions or subtraction and you only have to perform one level of binary operations on each step ( a few XORs or muxes per bit), without propagating the carry.
For example, divisions (particularly SRT divisions) can be done with many successive additions or subtractions. Using carry-save/borrow-save representations allows to reduce the cycle time, or to calculate more bits per cycle and, as there is no carry propagation, it does not depends on the operand size (for example the same cycle frequency is adapted for both single and double precision floating point).
Edit
Look for "borrow-save adder" for actual implementations . For example : http://users-tima.imag.fr/cis/guyot/Cours/Oparithm/english/Additi.htm
Edit
FA blocks are "full adders"
Take 3 inputs, A,B and C, each weighting 0 or 1. The result is between 00 and 11. A full adder is :
Carry = (A and B) or (B and C) or (A and C)
Sum = A xor B xor C
The bubbles around the adders are obviously inverters, 'NOT' gates
The 'Online' version on the right diagram processes bits serially instead of in parallel. I have the impression that the least significant bit should be provided first. Squares are memory/flipflops, the propagation time is therefore 3 clocks.
The adder
This diagram describes an adder taking two BS vectors (X+/X-) and (Y+/Y-) and generating one BS result (Z+/Z-). It can also be used to calculate the sum of two differences.
The problem I see is that you need the absolute value to calculate the 'sum of absolute differences'. I don't know how to convert to the absolute without doing a (carry propagating) comparison.
  • \$\begingroup\$ i updated the part i am not understanding the numerical example with the hardware example my application is calculation the SAD (sum of absolute differences) between an 8*8 block but to applying this example on 8 bit unsigned numbers i am not understanding the transition formula from step X and Y to H and G then to W and Z shown in the hardware picture \$\endgroup\$ Commented Sep 19, 2014 at 8:33
For your example, first convert 10 to -10 by flipping bits/adding 1:
formula1
Then perform the addition of [25 + (-10)] using 8-bit two's complement.
    \$\begingroup\$ yes but in this case the carry will propagate in the OLA adder it is carry free \$\endgroup\$ Commented Sep 18, 2014 at 13:42
