I'm looking to use a RBO40 reverse battery & over voltage protection. I was unable to find the RBO40-40T (with 3 pins) anywhere so had to get RBO40-40G, which is slightly different, it has the middle GND pin cut and the data sheet says this goes to the TAB instead.
I'm not really up on this chip packaging, how am I meant to connect this GND when the TAB is a flat metal surface on the back of the chip?
Data sheet is here
Thanks
