I am trying to make a module that will work like a queue with 4 slots. It is for an elevator and the currSt is the current state and destination is the first item in queue. 4'b1111 is like NULL. The problem here is that the queue doesn't get the input from the keyboard to be stored in the 4 free places. `
module Queue(
  input clk, slowclk,
  input[3:0] cs,
  output[3:0] currstat, des,
  input[3:0]keycode,
  output reg go
reg currSt;
initial currSt = 4'b1;
//1111 = empty place in queue
reg queueItem1 = 4'b1111;
reg queueItem2 = 4'b1111;
reg queueItem3 = 4'b1111;
reg queueItem4 = 4'b1111;
//continuous assignment
assign currstat = currSt;
assign des = (queueItem1 == 4'b1111)?currSt:queueItem1;
always@(posedge clk) begin
    if ((keycode == 4'b0001)
      ||(keycode == 4'b0010)
      ||(keycode == 4'b0100)
      ||(keycode == 4'b1000))
    begin
        if(queueItem1 == 4'b1111)
            queueItem1 = keycode;
        else if(queueItem2 == 4'b1111)
            queueItem2 = keycode;
        else if(queueItem3 == 4'b1111)
            queueItem3 = keycode;
        else if(queueItem4 == 4'b1111)
            queueItem4 = keycode;
        //else do nothing
    end
    //adds new key pressed to queue
    if (keycode == 4'b0001
     || keycode == 4'b0010
     || keycode == 4'b0100
     || keycode == 4'b1000)
    begin
        if (queueItem1 != keycode
         && queueItem2 != keycode
         && queueItem3 != keycode
         && queueItem4 != keycode)
        begin
            if (queueItem1 == 4'b1111
             && queueItem2 == 4'b1111
             && queueItem3 == 4'b1111
             && queueItem4 == 4'b1111)
            else if (queueItem1 != 4'b1111
                  && queueItem2 != 4'b1111
                  && queueItem3 != 4'b1111
            //else don't add the new one in the queue
        end
        //else if any of the slots is equal the keycode then dont add it
    end
    //check if current state matches with the request queue
    if (currSt == 4'b1000
     || currSt == 4'b0100
     || currSt == 4'b0010
     || currSt == 4'b0001)
    begin
        if (queueItem1 == currSt) begin
            queueItem1 = queueItem2;
            queueItem2 = queueItem3;
            queueItem3 = queueItem4;
            go = 0;
        end else if (queueItem2 == currSt) begin
            go = 0;
        end else if (queueItem3 == currSt) begin
            go = 0;
        end else if (queueItem4 == currSt) begin
            go = 0;
        end
        //if current state is not in the request queue
        else
            go = 1;
    end
end
always@(posedge slowclk)//change current state to new state
    currSt <= cs;
endmodule
The thing is that the register was supposed to be a 4 bit one and I declared it as 1 bit. There were too many warnings and my brain couldn't process them yesterday but I found it out today while trying to debug this crap. I suggest you all check the number of bits and the warnings carefully.
~over and closed~
