I'm trying to understand how the Verilog scheduling algorithm works. The below example outputs 0, xxxx
and not 1010
. I'm not clear why. If I do put a delay before $display
, it would output 1010
module test;
reg [3:0] t_var;
initial begin
t_var <= 4'b1010;
$display("%0t, %b", $realtime, t_var);
end
endmodule
Same output, 0, xxxx
, for the below example:
module test;
reg [3:0] t_var;
wire [3:0] y;
assign y = ~t_var;
initial begin
t_var = 4'b1010;
$display("%0t, %b, %b", $realtime, t_var, y);
end
endmodule
Based on the examples, it looks like that both nonblocking assignment and continuous assignment are two-step processes where the RHS is evaluated at the current time step and the LHS is scheduled to happen at the next time step (if no delay is specified) or at a later time step (if a delay is specified).
Can someone please confirm or explain to me a step-by-step flow of the algorithm below (from Clifford Cummings) as it applies to the examples above?
Thanks!
