I've started studying assembly, and I've been tryign to solve this problem:
For the following C statement, what is the corresponding MIPS assembly code? Assume that the variables f, g, h, i, and j are assigned to registers $s0, $s1, $s2, $s3, and $s4, respectively. Assume that the base address of the arrays A and B are in registers $s6 and $s7, respectively:
B[8] = A[i−j];
Source: Computer Organization and Design 5th Edition.
So, I did this:
sub $t0, $s3, $s4 // temp = i - j
sll $t0, $t0, 2 // temp = temp*2^2= 4*temp
add $t0, $t0, $s6 // temp = &A[i-j]
lw $t1, 0($t0) // t1 = temp
sw $t1, 32 ($s7) // B[8] = t1 = temp = A[i-j]
But looking at the book's solution manual to verify that my answer is correct, I got this:
sub $t0, $s3, $s4
add $t0, $s6, $t0
lw $t1, 16($t0)
sw $t1, 32($s7)
I am confused. How did they come up with the third statement lw $t1, 16($t0)
