I created a custom ip and added it to my design. I want to find out the speed of the clock. Is there any menu/option to find out in Xillinx platform studio or EDK?
  • \$\begingroup\$ Clock speed is usually derived from the hardware external to the FPGA. So how can software know about it? \$\endgroup\$
    – Eugene Sh.
    Commented Oct 25, 2016 at 14:22
  • \$\begingroup\$ @EugeneSh. The cpu is set at 50Mhz, it's a heterogeneous system. So it takes 20ns to run the vhdl logic? \$\endgroup\$
    – Oh hi Mark
    Commented Oct 25, 2016 at 16:17
You can check in the .mhs file that is created by EDK. In this file you will find a clock generator. Trace the input and output of this clock generator to know which IP runs at which frequency.
