Is there way to calculate slew rate of following circuit?
Datasheet for Transistor
Datasheet for Diode
I chose the PMOS and Diode arbitrarily from what I could choose from Circuit Lab.
If VTRIG goes from 5V to 0V, how can I calculate the slew rate (V/us)?
  • \$\begingroup\$ Uhhh datasheet? \$\endgroup\$
    – Bradman175
    Commented Dec 26, 2016 at 1:43
  • \$\begingroup\$ @Bradman175 I've added link to datasheet \$\endgroup\$
    – Steve
    Commented Dec 26, 2016 at 2:19
  • \$\begingroup\$ Now go into dynamic under specifications and look at the delay and rise fall times? \$\endgroup\$
    – Bradman175
    Commented Dec 26, 2016 at 2:52
  • \$\begingroup\$ poor choice of FET for -5V Vgs \$\endgroup\$
    – D.A.S.
    Commented Dec 26, 2016 at 3:27
  • A rough approximate is to use the RdsOn for -5V.
  • It is guaranteed to be 0.3Ω but that is for -10V @25'C with 7.2A Pulse, width = 300 μs; duty cycle = 2 %.
  • your situation is different and vague;
    • Initial conditions :
    • Vcap (unknown )
    • Cap part number (unknown ) and
    • trace inductance (unknown )
    • cap ESR or Dissipation Factor (unknown )
    • Diode ESR 1N4148 0.1W ~ 10ohm ( assumed to be larger than 1nF
    • Cap ESR which is expected to have ESR*C value=T < 0.1us for ceramic
    • The RdsOn starts at a high value due to Vdes =5V and Vgs=-5V and not being a "logic level" gate controlled FET requires a certain amount of calculations from the datasheet below enter image description here
With the slew rate being dV/dt=Ic/C for the cap and Ic = (V+-Vcap)/(RdsOn+ESR(diode)) it becomes highly nonlinear.
But with initial conditions of ESR diode=10, and ESR or RdsOn of FET=10Ω then dropping to 0.34 Ω as Vds drops below 3V.
  • Ic=C dV/dt=1e-9 * (5V)/(10Ω+10Ω) and C= 1e-9F for Vds=3~5V
slew rate dV/dt= Ic/C= 5V/20Ω*1e9= = 0.25V/ns
Low confidence in results due to inadequate info.
