In my free time I've been trying to implement some simple logic gates and circuits using BJTs only (BC547s are the ones I have lying around).
The circuit
I've successfully built inverters, NAND and NOR gates. However I ran into trouble when I tried creating some sort of "latching" circuit. Here's the logic diagram:enter image description here
Both A AND B need to be HIGH in order to turn on the output, but once it's on, A can go back LOW and Q will stay HIGH until A goes back LOW.
Here's what my attempt looks like using a NAND and NOR gate, each followed by an inverter:enter image description here
The base resistors are 10k and the collector resistors are 1k, VCC is 5V
The Problem
The circuit works. Sometimes. When I first tried it out, it worked like a charm. All of a sudden it stopped working. It would get stuck in the HIGH state when it should have been LOW and the other way around. I found out that if that happened, I could "flip" it into the correct state by touching resistor R8.
I'm a 2nd year EE student, I know about digital circuits (only on the logic gate level, not how they're implemented) and a bit about BJTs.
I'd greatly appreciate if somebody could shed some light on this for me.
Thanks, and a happy new year :)
The problem is the PN junction from the base to collector or T4. When T5 is off, the emitter of T4 is floating. If you now apply a high voltage to the left end of R5, T4 acts like a diode from base to collector. This turns on T6 directly from the high output of T3.
Put another way, the NAND gate formed by T4 and T5 has a bug. It doesn't work when the T4 input is high and the T5 input low. Your overall logic was right, but due to T5 being off, T4 doesn't work like the transistor you are assuming anymore.
To make a NAND gate, just flip your NOR gate around using PNP instead of NPN:
By the way, this whole problem goes away if you use logic-level N-channel MOSFETS instead of NPN transistors. You can stack those and get what you intended.
  • \$\begingroup\$ That worked like a charm! Thank you so much, also for the great explanation! :) \$\endgroup\$
    – Mathis
    Jan 2, 2017 at 13:55
  • \$\begingroup\$ I might be missing something, but why is this a problem? If I understand it correctly: When the base of T5 is low, the floating emitter of T4 results in T4 acting like a diode from base to collector, turning on T6. However, is that not exactly what we want here? If either T4 or T5 (or both) has a low input at its base, we want the left side of R6 to be high since we want T4/T5 to act as a NAND gate. In this case, the input of T4 is high and the input of T5 is low, resulting in a high left side of R6, just like a NAND gate is supposed to work. Can anybody provide some clarity here? \$\endgroup\$
    – s1m0n
    Feb 15, 2021 at 19:04
The two transistors from R9 down are operating (obviously) as a NAND gate. Lets call the top one T4. (I just saw that it is; the schematic has the reference a little bit away from the device).
Here is where transistors (I have seen this for bipolars and FETs) can be a pit picky: they usually need a solid DC ground bias path and the current through R8 may or may not properly turn on (or off) T4 under all circumstances.
A large value resistor (100k or so) from the base of T4 to ground should cure the issue.
Assume the output is high (T4 and T5 are both on), and you take B low; that turns off T5, but there may be sufficient leakage T4 will still conduct; touching R8 is probably sufficient leakage parasitics to provide a DC bias path and all is well again.
Another possibility is that the resistors are not quite correctly sized; when the feedback comes around to T1, the transient current will be interesting. I will look more closely and update this in the morning.
  • \$\begingroup\$ Thanks for the quick reply! I just tried putting a 100k between the base of T4 and ground, but still no luck so far.. \$\endgroup\$
    – Mathis
    Dec 30, 2016 at 17:24
  • \$\begingroup\$ When I pull input B LOW the output will switch off, the problem is mostly getting it to turn ON when both inputs are HIGH. \$\endgroup\$
    – Mathis
    Dec 30, 2016 at 17:25
  • \$\begingroup\$ Try probing at the collector of T4 preferably with a scope but a DMM should yield useful information (this may actually cause the circuit to work). \$\endgroup\$ Dec 30, 2016 at 17:26
  • \$\begingroup\$ Check the voltage at the collector of T2 when trying to turn it on. \$\endgroup\$ Dec 30, 2016 at 17:31
