I have designed a system using Artix-7 FPGA on a custom board. The goal is to transfer 32-bit data to an external onboard chip whose data bus is an inout
port. First, a little background:
The external chip is driven by a 100MHz clock which is generated by the FPGA, let's call it o_clk
. The FPGA generates this clock through an MMCM in the Memory Interface Generator (MIG IP) using the 200MHz differential system clock. The o_clk
is looped back from the FPGA's output and is given to another ball as an input clock, let's call it i_clk
The external chip receives the o_clk
and sees data on this clock's rising edge. However, when the external chip sends data back to FPGA, the FPGA sees this data on the looped back i_clk
. The idea behind doing so is that we can treat communications as source synchronous, in both the directions (remember, it is an inout
port). Something like below:
FPGA --> EC is synchronous to FPGA because FPGA generates a clock
EC --> FPGA is synchronous to EC because FPGA gets an external clock (virtually from EC)
To constrain this design, I have used the i_clk
to set input delays on the io_data
and have used the o_clk
to constrain output on the same io_data
bus. I have made sure I am using a forwarded clock (create_generated_clock
)(using the ODDR2) for the set_output_delay
constraint.
Here are my constraints:
create_clock -period 10.000 -name i_clk -waveform {0.000 5.000} [get_ports i_clk]
set_clock_groups -name loopback_grp -asynchronous -group [get_clocks i_clk] -group [get_clocks o_clk]
set_input_delay -clock i_fx3_pclk -max 8.000 [get_ports io_fx3_fdata]
set_input_delay -clock i_clk -min 2.000 [get_ports io_data]
set_output_delay -clock o_clk -max 2.000 [get_ports io_data]
set_output_delay -clock o_clk -min -0.500 [get_ports io_data]
The system seems to work properly when I run it on hardware, but I still have some doubts because I am still an amateur FPGA developer and this is my first big FPGA design.
My questions are:
- Have I designed a good system?
- Is it correct to treat the communication from EC --> FPGA as source synchronous? (The other direction is source sync because FPGA is providing clock if I am not wrong.!)
- Are my constraints correct?
i_clk
is asynchronous too_clk
. Did you intend this? If you want to make them synchronous, you must define them in the same clock group. For example,-group [get_clocks "i_clk o_clk"]
. \$\endgroup\$i_clk
is looped back in hardware and it doesn't know that both the clocks are related. Should I make them synchronous in a design point of view.? \$\endgroup\$
