I have a T1635H-T triac, that i would like to control with MOC3041. I use typical circuit from the optocoupler datasheet:
The only difference is that i'm using 330Ohm resistor instead of 360Ohm. As a test load i use 40W incandescent bulb.
For some reason, when i enable the optocoupler by closing led-side circuit, triac burns almost immediately with clearly visible clearly visible traces of damage on the gate pin.
What i'm doing wrong?
