i simulate Dual Port Ram Register in VHDL and have some doubts about the metastability problem.
Dual Port Ram has 2 clock signal, one for Port A , the second for Port B. In my simulation I create two processes with 2 differentes clocks.
type memory_type is array(0 to adress_width) of std_logic_vector(data_width-1 downto 0); --> memory array
signal memory_sgnl : memory_type := (others => (others => '0'));;
begin
-- Port A
process(clk_a)
begin
if(rising_edge(clk)) then
if(rising_edge(clk_a)) then
if(we_a = '1') then
memory_sgnl (addr_a) := data_in;
end if;
data_out<= memory_sgnl (addr_a);
end if;
end process;
-- Port B
process(clk_b)
begin
if(rising_edge(clk_b)) then
if(we_b = '1') then
memory_sgnl (addr_b) := data_in;
end if;
data_out<= memory_sgnl (addr_b);
end if;
end process;
I have found a post here. Mr Jim Lewis made a suggestion how DP Ram with 2 clocks can be simulated. He did the same implementation. So i can conclude I did correctly.
BUT I have read We need to solve a problem metastability, because there 2 clock signal : clock time crossing.
clk_crossing: process(clk, rst)
begin
if rst ='1' then
a_clk_b <= '1';
a_clk_bb <= '1';
b_clk_b <= '1';
b_clk_bb <= '1';
elsif rising_edge(clk) then
a_clk_b <= a_clk;
a_clk_bb <= a_clk_b;
b_clk_b <= b_clk;
b_clk_bb <= b_clk_b;
end if; -- if rst ='1' then
end process clk_crossing;
and then the processes should be process(a_clk_bb )
and process(b_clk_bb )
Will be it correct? Did I understand correctly how to solve metastability question?
EDIT 1
The simulation of RAM is a "part" of SPI slave. SPI slave will send 8 bits vector data to RAM ( buffer of data). It has only one system clock and SPI clock + write_enb_signal ( FIFO is full and is ready to send data to RAM) . I thought Dual port RAm will work with system clk and write_enb_signal.
process(clk_a)
begin
in the simulation spi slave there is no additional clk signal for clk_a or clk_b...
Should I create one?
