The following code snippet is an example from a SNUG 2000 paper that explains race conditions. The explanation for the race condition is given below, but I do not understand it. How is y1 and y2 = 1 if the first always block executes first? Or 0 if the second block executes first? Can someone please explain the order of execution each statement?
Moreover, when the explanation says "after a reset", does it mean after a reset signal is asserted or de-asserted?
Code:
module fbosc1 (y1, y2, clk, rst);
output y1, y2;
input clk, rst;
reg y1, y2;
always @(posedge clk or posedge rst)
if (rst) y1 = 0; // reset
else y1 = y2;
if (rst) y2 = 1; // preset
else y2 = y1;
endmodule
Explanation:
According to the IEEE Verilog Standard, the two always blocks can be scheduled in any order. If the first always block executes first after a reset, both y1 and y2 will take on the value of 1. If the second always block executes first after a reset, both y1 and y2 will take on the value 0. This clearly represents a Verilog race condition.
