I have a question about ferrite beads. The DC resistance of the ferrite bead is an important parameter for picking up our design. This value has to be as low as it can because if the current drawn increases where we use it, it causes a voltage drop and it might create a problem in the place where the sensitive voltage need.
When we place a ferrite bead on the supply voltage of a 100MHz crystal oscillator (for example, the ferrite bead used has a 1k ohm resistor value at 100MHz,) does the ferrite bead cause any problems for that crystal oscillator? I know, 100MHz signal produced is in the output pin of oscillator, but does it generate also noise on the supply side while generating this signal?
