A typical PFET reverse polarity detection circuit looks like this
I was wondering if it is possible to use that same PFET to choke some power off to the load by adding a voltage divider using something like the following . .
The simulation output shows 11.76A to load, even though the data sheet for the component is shows the following, so with a Vds of 48V I would expect to see some reduction in current in the LTSpice simulation with a VGs of less than 4.5V.
Few options:
- The spice simulation is not working correctly (used the spice model from vendor here)
- The spice sim is accurate and I'm not understanding something.
- This circuit is a fundamentally bad idea for other reasons
