I came across this post on how to reduce EMI in a PCB. From this, I learned that there actually exist two types of current. The first is the conductive current (the current that flows through a conductor) and the second is magic (or displacement current). This displacement current is 99.9999999% the reason why electronics is considered black magic :).
In the post they show that it is best to use smaller traces for high frequency is a must! From Maxwell's equations:
The contribution from Maxwell is the second term in the parentheses, this term explains how much displacement current will exist.
Basically having a smaller conductive area, reduces this term and thus the magnetic field created for high-speed signals. Hence reducing unwanted EMI emissions and interference with neighboring tracks.
The post included this picture:
Please see link here
My questions:
Is what I explained above correct?
I know that adding a ground plane to the bottom layer of the PCB helps with EMI, however, how does it help exactly? I am assuming is reduces the capacitance, but how does it reduce it?
