i get this error:
avrdude: stk500_getsync(): not in sync: resp=0x00
when trying to upload a example sketch.
pin (0,1) are not occupied; it is the right serial port with latest drivers i choosed the right board
The RX led blinks 2 or 3 times when i try to upload.
Full log:
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "D:\Utz\Downloads\arduino-1.0.4\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude done.  Thank you.
  • \$\begingroup\$ Are you programming an AVR from within the Arduino IDE? \$\endgroup\$
    – jippie
    Commented May 14, 2013 at 17:40
5 Answers 5
Try hitting the RESET button just around the time avrdude starts. Maybe you were not entering the boot loader—the Nano is supposed to have auto-reset, but maybe that’s not working in your setup.
Indeed, as Igor mentioned, installing those FTDI drivers works.
Install this driver after windows automatically installs usb driver. http://www.ftdichip.com/Drivers/CDM/CDM20824_Setup.exe It worked for my arduino nano =D
On Windows, The CDM 20.08.24 driver solved my Nano problem as well.
  1. Uninstall previous com port ftdi driver via "Device Manager", select delete software option
  2. Install the recommended 20824 driver
  3. Restart as Windows recommends.
  4. Nano 3.0 is now programmable!
Prevent Arduino from resetting
Make sure there is:
  • a 120 ohm resistor between Vcc (+5V) and the Arduino's \$\overline{\text{RESET}}\$ pin
OR
  • a 10μF capacitor from \$\overline{\text{RESET}}\$ to GND.
When the programming cycle starts, Arduino will reset when one of the above hacks is not in place. The PC software will timeout before Arduino is back online.
Baudrate
Find this line in your ArduinoISP sketch, the software you use to turn Arduino into an AVR programmer:
Serial.begin(19200);
and change it to:
Serial.begin(57600);
Upload, retry.
  • \$\begingroup\$ While I can't entirely rule it out, this doesn't really sound like an ISP situation to me; rather I suspect just a usb-serial cable used with the bootloader on the target chip. \$\endgroup\$ Commented Sep 12, 2013 at 14:58
