This is a problem solving for the voltage across a capacitor with initial conditions. After finding initial conditions and transforming into s-domain, the circuit looks like this:
So, the voltage we are solving for includes both the capacitor and the voltage source in s-domain. $$ V(s) = I\frac{25}{s}+\frac{60}{s} $$
I can get the correct answer for this problem using the equation below from mesh analysis and the equation above:
I(\frac{25}{s}+\frac{s}{4}+10)=-\frac{60}{s}
However, initially, I thought voltage division might be easier. I thought the node between the inductor and the capacitor would be the same as V(s), just negative as we would have to assume the current is going in the opposite direction of \$I\$ for the voltage division.
V(s) = -\frac{60}{s}\cdot\frac{10+0.25s}{10+0.25s+25/s}
However, this does not lead to the correct answer.
I am wondering what is conceptually wrong with my voltage division equation.
