I am trying to create a custom data type which I am creating in a package using Xilinx ISE 14.5. I am trying to create a generic DEMUX to switch between buses, here is the code of the generic DEMUX:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use work.CustomDataTypes.all;
entity GenericDEMUX is
-- Ancho del bus de cada salida y número de salidas
generic( busWidth : integer := 4;
channelsNumber : integer := 4
Port ( Output : out Matrix(channelsNumber-1 downto 0, busWidth-1 downto 0);
Control : in integer range 0 to channelsNumber-1
end GenericDEMUX;
architecture Behavioral of GenericDEMUX is
begin
end Behavioral;
So I created a Package to contain Matrix
data type:
CustomDataTypes.vhd:
package CustomDataTypes is
type Matrix is array (natural range<>) of STD_LOGIC_VECTOR (natural range<>);
end CustomDataTypes;
When I do Check Syntax
on the Generic DEMUX I get this errors:
ERROR:HDLParsers:164 - "//vboxsrv/datos/Datos/Micro UTN/FPGA/MaquinaEstados/CustomDataTypes.vhd" Line 14. parse error, unexpected NOTCONSTRAINT
ERROR:HDLParsers:3009 - "//vboxsrv/datos/Datos/Micro UTN/FPGA/MaquinaEstados/CustomDataTypes.vhd" Line 35. Package CustomDataTypes does not exist.
I don't know what parse error, unexpected NOTCONSTRAINT
means but I think it could be related to Package CustomDataTypes does not exist
. Here is a Screenshot of what my Libraries tab looks like, as you can see CustomDataTypes.vhd
is there:
However I don't see it in the design tab:
I tried adding it but it says it already exists.
