I found this CMOS circuit in my textbook. It says that when input voltage is 0V, the output voltage is 0V, and IDN and IDP are both zero. I think that the output voltage is 0V due to some form of symmetry. However, I could not understand as to why IDN and IDP are both zero. Could anyone please explain? Thanks.
Both transistors would have Vgs below their respective threshold voltage, so only leakage current would flow Drain-to-source.
Consider this circuit as two complementary source-followers connected together, each with 20K source resistors.
