I want output to equal "11111111" on the first rising edge of the clock but it only happens on the second rising edge when I test the code with ModelSim. The code might look weird as a simplification of a more complex design where I have the same kind of problem.
code:
library ieee;
use ieee.std_logic_1164.all;
entity delay is
port(
clock : in STD_LOGIC;
output : out STD_LOGIC_VECTOR(7 downto 0) := "00000000"
end delay;
architecture behavioral of delay is
signal debug : STD_LOGIC_VECTOR(3 downto 0);
begin
process(clock)
begin
if rising_edge(clock) then
debug <= "0000";
case debug is
when "0000" => output <= "11111111";
when others => output <= "00000000";
end case;
end if;
end process;
end behavioral;
testbench:
library ieee;
entity eentestbench is
end eentestbench;
architecture behavioral of eentestbench is
signal clock : STD_LOGIC := '0';
signal result: STD_LOGIC_VECTOR(7 downto 0) := "00000000";
component delay
port(
end component;
begin
uut : delay port map(
clock => clock,
output => result
stim_process: process
begin
clock <= '0';
wait for 1 ns;
clock <= '1';
wait for 1 ns;
end process;
end behavioral;
