Is it possible to generate different set of constants in a vhdl preamble using a kind of "if generate statement"?
For example I was trying:
library ieee; use ieee.std_logic_1164.all;
entity my_entity is
generic(flag : integer);
port(x : in std_logic_vector(31 downto 0);
y : out std_logic_vector(31 downto 0));
end entity my_entity;
architecture arch of my_entity is
flag_true : if flag /= 0 generate
constant K1 : integer := 32;
end generate flag_true;
flag_false : if flag = 0 generate
constant K2 : integer 32;
end generate flag_false;
begin
flag_true_conc : if flag /= 0 generate
y(K1 - 1 downto 0) <= not x(K1 - 1 downto 0);
end generate flag_true_conc;
flag_false_conc : if flag = 0 generate
y(K2 - 1 downto 0) <= x(K2 - 2 downto 0) & x(K2 - 1);
end generate flag_false_conc;
end architecture arch;
But when I run the ncvhdl for the syntax check it returns me loads of errors:
ncvhdl: 14.20-s029: (c) Copyright 1995-2016 Cadence Design Systems, Inc.
ncvhdl_p: *E,EXPBEG (entity_test.vhd,10|34): expecting the reserved word 'BEGIN' [1.2].
ncvhdl_p: *E,EXPBEG (entity_test.vhd,13|35): expecting the reserved word 'BEGIN' [9.7].
ncvhdl_p: *E,EXPSMI (entity_test.vhd,17|28): expecting a semicolon (';') [4.3.1.1].
ncvhdl_p: *E,EXPBEG (entity_test.vhd,17|32): expecting the reserved word 'BEGIN' [9.7].
ncvhdl_p: *E,EXPEND (entity_test.vhd,18|28): expecting the reserved word 'END' [1.2].
I don't think except for the if generate in the preamble I've done something weird.
Assuming I made you understand what I'm trying to achieve is it possible to do that?
(You have to imagine the situation where in the preamble I want to generate different set of constants based on some kind of flag or condition).
