What connections (e.g. between gate, drain, source, body, and surrounding circuit) are implied by this MOSFET symbol with a line through it (M3)? For comparison, here is another NMOS transistor from the same paper without a line through it (M4).
NMOS with line through it Normal NMOS schematic
    \$\begingroup\$ IS there another one to the right of it. It is common to draw gates joined like that. (Or bases for BJTs) \$\endgroup\$
    – Trevor_G
    Commented Dec 5, 2017 at 2:25
  • \$\begingroup\$ M4 is to the right of M3 with a resistor in between. To the left of M3 is a capacitor \$\endgroup\$
    – Alex
    Commented Dec 5, 2017 at 2:32
Through-routed gates
It's common in IC schematics to route a connection through the base/gate of a transistor -- that means "connect to this base/gate and keep going" in a compact and efficient way, vs. having to tap off a wire and route around the transistor symbol. No body connections are implied by the through-routing, by the way.
