Currently I am designing a 4-layer PCB, with the layers as follows:
  • (1st layer, top) signal
  • (2nd layer) ground
  • (3rd layer) power
  • (4th layer, bottom) signal
The clock frequency is either 8 MHz (running at 3.3V) or 16 MHz (running at 5V). There are no active RF components on the board, just surface-mounted SPI-based devices. The total board dimensions are ~4cm x ~3cm.
My current design has no copper pour on the signal layers, but have copper pour on the ground and power layers.
So under these circumstances, would it make any difference whether or not I have a copper pour on the top and bottom signal layers?
  • \$\begingroup\$ Will this board have a data or address bus where flight-time and capacitive loading would be an issue? How complex is this board? Mixed signal types? \$\endgroup\$
    – user105652
    Commented Mar 31, 2018 at 0:43
  • \$\begingroup\$ There is no address bus; the individual SPI devices are activated via digital outputs from a microcontroller. There are data transmitted from the SPI devices, so perhaps that can be considered a data bus. The board is purely digital, no mixed signal types. \$\endgroup\$
    – plu
    Commented Mar 31, 2018 at 0:47
    \$\begingroup\$ Remember the copper is already there. You pay the board house to etch away what is not needed. Extra ground pour is ok but 2 layers of it means a lot of vias. \$\endgroup\$
    – user105652
    Commented Mar 31, 2018 at 1:31
    \$\begingroup\$ @analogsystemsrf And no, I do not need to pass FCC tests, the design is more for research purposes. How would edge speeds and trace lengths influence whether or not copper pours are required? \$\endgroup\$
    – plu
    Commented Mar 31, 2018 at 2:58
    \$\begingroup\$ If you have very fast edges, the copper pours will tend to become antennas because the traces will couple to the same-layer pours. Read what Neal_UK says below. \$\endgroup\$ Commented Apr 1, 2018 at 2:14
6
All copper on the board should be consciously designed.
I am against copper pours on principle, because they seem to cause more problems than they solve - increased stray capacitance, confusion about where return currents are flowing, unintentional coupling between signals, or creation of an antenna. It can complicate debug and modification as well.
They seem to lead to a lazy mindset, where the designer thinks 'well there's lots of copper on the board, surely the grounding will be OK now!' A copper pour is unnecessary, and insufficient to achieve a good board.
There are good reasons to use a copper pour, thermal conductivity, reducing the amount of etch solution used, improving thickness tolerance, reduction of warping, beefing up of tracks, but 'should' isn't one of them.
  • \$\begingroup\$ All agreed. Just to add one consideration: with extra copper parasitic capacitance may couple between remote and unrelated circuits, like switching power supply and op amp feedback on other side of the board. \$\endgroup\$
    – user76844
    Commented Mar 31, 2018 at 6:17
  • \$\begingroup\$ Thanks, in that case, I will keep the top and bottom signal layers of the design without any copper pour. \$\endgroup\$
    – plu
    Commented Apr 1, 2018 at 13:57
~4Mhz can be done single-sided - Sega did a Z-80 based home computer on single-sided FR2. 16Mhz is not radically more especially when the traces are only 5cm or so long (vs 20cm in the single sieded computer)
With only 5cm traces, you can probably do the same for your design, (although double sided makes routing easier, and more layers will give you a ground plane if you really need it.
If you put both the power pours close together they act as another power supply de-coupling capacitor.
Surface pours can be useful for heat-sinking if you have some power parts could benefit from that, but act as antennas for electrical fields so don't use them for fast or high-impedance signal nodes.
Unless you're making this in production quantities the board house only charges for the area of the PCB material and the number of layers, so you don't get any credit for the copper they reclaim. Copper is expensive so the don't flush used etchant doiwn the drain but instead recycle it, reducing both waste and costs. So they're probably glad to have large etched areas.
    \$\begingroup\$ Interesting - didn't know about sega doing single-sided boards, but it looks like they did 3 different designs: the SG-1000, the SG-1000 II and the Sega Mark III are all on single-sided boards, and seems didn't need all that many links to be applied, either. Incidentally, they didn't run at 4MHz - the CPU ran at about 3.6MHz, but the graphics processor ran at 10.7MHz and its dedicated RAM was connected via a bus that could switch twice (i.e. to provide RAS and CAS commands) in 3 processor cycles, so was effectively ~7MHz. But then, 7MHz can be done on breadboard (google: grant searle CPM). \$\endgroup\$
    – Jules
    Commented Mar 31, 2018 at 18:18
