5
Many sources claim that when the base-emitter voltage becomes smaller than approximately 0.6V-0.7V, the bipolar junction transistor goes in the cutoff region and there is zero base and collector current.
Of course this is not completely true, since there will be some (exponentially decreasing) current for lower values of Vbe, and this exhibits the characteristics of diodes operated at low voltage (with an exponential I-V characteristic).
Does the Ebers-Moll model accurately predict the behavior of the BJT in cases where Vbe is so small that the base current becomes on the order of pA (10e-12 A)? In general there is a current gain parameter called beta ~ 5 - 100 which relates the collector current to the base current, but does this beta decrease if the base current becomes extremely small?
I am asking this because I have a particular application where I need extremely low currents, and I am not sure if the simulator (Cadence Spectre with foundry-provided npn models) is reliable in this unusual region of operation. I know that it uses the Gummel-Poon integral charge model, but this should be close to the Ebers-Moll model at low currents, I expect.
  • \$\begingroup\$ Tob, are you working with a foundry? Because they don't usually give out their models easily, unless you are working with them. If so, their models tend to work well even on the low currents you mention. But ask, of course. (Likely VBIC or Philips MEXTRAM models. Or, in some specialized cases, HICUM.) Also, regarding Ebers-Moll, you could look over what I wrote here about low currents and the problems modeling them. \$\endgroup\$
    – jonk
    Commented Sep 17, 2018 at 23:00
  • \$\begingroup\$ Finally, be aware of shot noise issues. Anytime a current crosses a PN junction, it's "randomized" (poisson) and leads to noise. For example, suppose you have a base current of \$10\:\text{pA}\$. Then you can expect \$2\:\frac{\text{fA}}{\sqrt{\text{Hz}}}\$ on that score alone. At a bandwidth of, say, \$1\:\text{kHz}\$ this would imply getting very near 1% of your base current as noise due only to this effect. If these low currents result from a diode detector, you can also expect another quantum effect from the light itself: a kind of "flocking," since bosons can be in the same quantum state. \$\endgroup\$
    – jonk
    Commented Sep 17, 2018 at 23:09
  • \$\begingroup\$ I work (indirectly, through the university) with a foundry (signed an NDA), and I am using the models provided with the design kit from the foundry, but I believe from reading the Spectre simulator documentation that the bjt model used is "integral charge Gummel-Poon model". The foundry just provides specific parameters to a bjt instance in their custom .scs model file. \$\endgroup\$
    – Tob Ernack
    Commented Sep 19, 2018 at 13:41
  • \$\begingroup\$ You should probably ask your foundry, then. They know what they gave you. Gummel & Poon's seminal 1970 paper is titled, "An integral charge control model of bipolar transistors." Spice uses an improved GP model, so I'm not even sure if your simulator is up to date in that respect, from what you write. Note also that, for example, LTSpice includes a VBIC and MEXTRAM models, as well. I know that the Spice GP model includes low current effects. I just don't know how good those models are, since I've not attempted validating modeled collector currents under a nanoamp in a practical circuit. \$\endgroup\$
    – jonk
    Commented Sep 19, 2018 at 16:46
I understand your issue. Personally I would not expect either model (Ebers-Moll nor Gummel-Poon) to produce accurate results with such low currents. The models are neither designed nor verified for that region of operation.
Also I think that leakage and temperature related issues (and we all know that leakage and temperature have strong relations) will influence the currents dramatically. Often these effects are poorly modeled.
And even if the models could support accurate modeling at such low currents then the question remains if the model parameters are in any way reliable. If the transistor's manufacturer (foundry) did not measure and extract those parameters at such low currents then no one can say anything about reliability of the models.
  • \$\begingroup\$ I see, in that case the only way I will know for sure is if I implement the circuit and experimentally verify it. Though I'd prefer not having to do that if it can be avoided. In my application, I don't really need to have precise values for the current and for beta, but I do need to be sure that the base current does not go above a few pA, and that the collector current will still have some proportionality to this base current. \$\endgroup\$
    – Tob Ernack
    Commented Sep 12, 2018 at 14:27
    \$\begingroup\$ Since you're doing things in the pico-ampere range, leakage currents matter and those currents can find their way through even some dirt on your PCB. You may find this EEVBlog video interesting: youtube.com/watch?v=QFOH8n43kY4&t= as it shows what a design needs to operate properly with very high resistance values and extremely small currents. \$\endgroup\$ Commented Sep 12, 2018 at 16:07
  • \$\begingroup\$ Do these leakage currents also arise in integrated circuits instead of PCBs? I guess you have a point, that if there is another leakage path, such as small conductance across the inter-metal insulation layers then I would need to worry about this as well... \$\endgroup\$
    – Tob Ernack
    Commented Sep 12, 2018 at 16:17
    \$\begingroup\$ Do these leakage currents also... I would turn it around and say: you're lucky if they're not there. You might know that common resistors you can buy go up to 22 Mohm (that's the highest I have here), special ones might go up to 100 Mohm (just my guess). Let's say I have 1 Volt and 100 Giga ohm (1000x more than 100 Mohm) that 1 V across it already results in 10 pA. So the trick is to stay above 100 Gohm, that's a challenge! \$\endgroup\$ Commented Sep 12, 2018 at 16:33
    \$\begingroup\$ So I suppose you're suggesting that typical insulators used between metal layers won't be good enough to avoid these sorts of leakages? On-chip metal layers are separated by SiO2, I think that would provide enough isolation. The problem is the devices in the silicon, diodes and MOSFETs all have leakage currents and though small, they will be much larger than the currents you're interested in. \$\endgroup\$ Commented Sep 12, 2018 at 20:52
