I wrote an ASRAM in VHDL and simulate it. I get many "X" if I try to read. I know that this problem is caused by too many drivers on one net but I didn't find the problem nor solved it.
Appreciate some help.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.std_logic_unsigned.all;
use IEEE.std_logic_arith.all;
use work.mem_type.all;
entity async_sram_tristate_new_nBit_test is
generic ( DAT_WIDTH: natural := 16; -- number of data bits
ADDR_WIDTH: natural := 6); -- number of address bits
port ( ram_dat : inout std_logic_vector ((DAT_WIDTH - 1) downto 0); -- bidirectional data bus to/from the SRAM device
ram_addr: in std_logic_vector ((ADDR_WIDTH - 1) downto 0); -- address bus of the SRAM device
nCS : in std_logic; -- low-active Chip-Enable of the SRAM device; defaults to '1' (inactive)
nOE : in std_logic; -- low-active Output-Enable of the SRAM device; defaults to '1' (inactive)
nWE : in std_logic; -- low-active Write-Enable of the SRAM device; defaults to '1' (inactive)
clk : in std_logic;
data_fpga_read : out ram_array_16(0 to (2**(ADDR_WIDTH-1) - 1));
data_fpga_write : in ram_array_16(0 to (2**(ADDR_WIDTH-1) - 1))
-- ram_wait : out std_logic := '0'); -- wait pin to stretch the strobe period; defaults to '0' (inactive)
end async_sram_tristate_new_nBit_test;
architecture Behavioral of async_sram_tristate_new_nBit_test is
constant ADRR_HALF : natural := 2**(ADDR_WIDTH-1);
constant MEM_SIZE : natural := 2**(ADDR_WIDTH);
constant DEPTH : natural := 1;
signal ram : ram_array_16(0 to 2**(ADDR_WIDTH) - 1); -- declerates a variable ram of type ram_array // this is the REAL memory
signal ram_output_buffer : std_logic_vector ((DAT_WIDTH - 1) downto 0); -- declerates a variable ram of type ram_array to buffer the output
signal addr_buffer : std_logic_vector((ADDR_WIDTH - 1) downto 0);
signal nWE_buffer, nOE_buffer : std_logic_vector(DEPTH downto 0);
begin
-- TRISTATE BUFFER
ram_dat <= ram_output_buffer when nOE_buffer(DEPTH) = '0' else (others => 'Z'); -- tristate buffer
-- ADRESS READ AND BUFFER
read_addr: process(clk)
begin
if(rising_edge(clk)) then
addr_buffer <= ram_addr;
end if;
end process;
-- READ PROCESS
read_ram : process (clk)
begin
nOE_buffer <= nOE_buffer(DEPTH - 1 downto 0) & nOE;
if (nOE_buffer(DEPTH) = '0') then
if (addr_buffer(ADDR_WIDTH - 1) = '0') then -- checks if the adress is in the "read-only" space
ram_output_buffer <= ram(conv_integer(unsigned(addr_buffer))); -- makes the data aviable via the output buffer
end if;
end if;
end if;
end process;
-- WRITE PROCESS
write_ram : process(clk)
begin
nWE_buffer <= nWE_buffer(DEPTH - 1 downto 0) & nWE;
-- nWE = 0 indicates that the microcontroller wants to write data
if (nWE_buffer(DEPTH) = '0') then
if (addr_buffer(ADDR_WIDTH -1) = '0') then
ram(conv_integer(unsigned(addr_buffer))) <= ram_dat;
end if;
end if;
end if;
end process;
--ram(2**(ADDR_WIDTH-1) to (2**ADDR_WIDTH)-1) <= data_fpga_write;
--data_fpga_read <= ram(0 to (2**(ADDR_WIDTH-1)- 1));
end Behavioral;
