The thing is: new data is being generated every "time step" that can be few clock cycles. So I want to store the data generated for few time steps in a "buffer". The data must be stored like in a queue. That is, the latest datum goes at the end of the queue and the first one is discarded. All the rest are moved one step ahead. That is, the second becomes the first, the third becomes the second and so on.
I want to avoid registers to save circuit area. That is why I am thinking of using on-chip memory like SRAM.
It can be understood as a FIFO based in RAM in which I could access any stored element by means of an address.
Something like:
entity special_fifo is
generic (
WIDTH : natural := 8;
DEPTH : integer := 32;
WIDTH_DEPTH : integer:=5
port (
clock : in std_logic;
reset : in std_logic;
wren : in std_logic;
ren : in std_logic;
address : std_logic_vector(WIDTH_DEPTH-1 downto 0);—-This is the thing that I would like to have
data : in std_logic_vector(WIDTH-1 downto 0);
q : out std_logic_vector(WIDTH-1 downto 0)
end special_fifo;
Can anyone clarify if it is doable?
Another way to ask the question could be:
Is it possible to shift the elements stored in RAM as if they formed an array. Something like this: RAM(address)<=RAM(address+1).
The number of clock cycles required does not matter in principle.
Edit: The data does need to be moved in the ram. It is data that has to be updated (thats why the latest is incorporated whereas the oldest is removed). Every single element of the current data must be accessible by means of the address. It is like updating a matrix row by row.
