I'm new to LTspice and I need to measure all the possible values of the drain current of a JFET when certain combinations of Vds and Vgs values are reached. That is, I need to record specific points of the output curve of the JFET.
For example: Vgs will vary from 0 to -5V in -1V steps; for each Vgs value, Vds will vary from 0 to 10V in 0.5V steps; for each Vds in each Vgs I need to record the drain current.
This could be done with nested .step directives if Vds was a voltage source (so I could use a {Vds} param), but I have this circuit instead:
Any idea is welcome.
Thanks in advance.
<My Documents>/LTspiceXVII/examples/Educational/IGBT.asc
for a way of doing a DC sweep. It's about an IGBT, but it can be used for any transistor. \$\endgroup\$
