I am about to make a revision of a PCB that has 60 mills of Intra-Pair Skew in PCI-E (Gen 2) RX differential pair:
Considering the capacitors the skew is ~50 mills:
this is the relevant part of the stack up for my question:
the traces are on layer 1, and the chip is on bottom layer (overall 6 layers) . the traces have 85 Ohm impedance.
Looking in Wikipedia, I learned that for 5 GT/s (Gen 2) the limit is 8 ns skew. how can I approximate if the 60 mills skew are critical in my case?
since the layout is so dense, I can barely do anything to minimize the skew. I was wondering if I can leave everything the way it is right now without affecting the performance.
Note: This design is a board that converts from PCIE to USB 3.0 using VIA-LABS VL805-Q6 Host Controller.
Additional Question:
- did anyone understand where did the 20 picosecond in the first answer come from? how it was calculated?
