Background info:
Hi, I am looking at a Reconfigurable Intelligent Surface (RIS) board fabricated according to the specifications in the OpenRIS project (https://github.com/jimrains/OpenRIS). In their design, they use MICROCHIP HV5308 shift registers to control the RIS elements.
My observation:
I notice in the Gerber files that the shift register's physical pin 29 and 30 are shorted, i.e., connected together:
Looking at the datasheet for MICROCHIP HV5308 (https://github.com/jimrains/OpenRIS/blob/main/hardware/datasheets/HV5308.pdf), this implies that the high voltage power rail and low voltage logic power rail are being given the same voltage supply line, which is currently about 2V. Please see image below:
My questions:
- What is the purpose of the high voltage and low voltage power rails?
- Is it normal to have the same voltage supply for high voltage power rail and low voltage power rail?
- Is there a rationale behind why they are made to have the same voltage supply?
I'm a beginner in electronics, so any information at all would be helpful.
