I have a simple buck converter made from TL494.
I saved my project and closed it. I opened it and tried to add a component. Whatever I add to the schematic and import changes to PCB, I have 2 errors which are:
Failed to add class member
Unknown Pin
Before I closed the project everything was fine, although I copied the same component which was imported to pcb successfully is not being imported now .
I tried Tools > Update from PCB libraries, but it didn't work.
I tried Force Annotate All Schematic, I only solved the ' Unknown pins' error. Failed to to add class member error remains. How can ı solve this issue?
Source: My project, when I click on 'Update from pcb library'
