I am new to VHDL and tried to implement a simple example from a book, what represents a 2bit register and the testbench.
Compiling the files works well, and signals the stimulate the register (reset, clock and data) are correctly transmitted from the testbench to the register.
But the assignment of internal signals to any value remains without any action, thus there is also no output.
I tried to simulate it with ModelSimPE Student Version and Xilinx Viacom Webpack edition 2014.3 .
In both IDEs I included the files, and they compile without any errors.
q0_s, q0_ns, q1_s, q1_ns
will not change their values, and thus there is no output.
Can anyone tell me, what is wrong with my code?
The 2bit register
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY reg2 IS
PORT (
clk : IN std_logic;
d0 : IN std_logic;
d1 : IN std_logic;
load: IN std_logic;
res : IN std_logic;
q0 : OUT std_logic;
q1 : OUT std_logic
END reg2;
ARCHITECTURE beh OF reg2 IS
SIGNAL q0_s, q0_ns, q1_s, q1_ns : std_logic;
BEGIN
reg : PROCESS (clk, res)
BEGIN
IF res = '1' THEN
q0_s <= '0';
q1_s <= '0';
ELSIF clk'event AND clk = '1' THEN
q0_s <= q0_ns;
q1_s <= q1_ns;
END IF;
END PROCESS reg;
q0 <= q0_s AFTER 2 ns;
q1 <= q1_s AFTER 2 ns;
mux : PROCESS (load, q0_s, q1_s, d0, d1)
BEGIN
IF load = '1' THEN
q0_s <= d0 AFTER 3 ns;
q1_s <= d1 AFTER 3 ns;
ELSE
q0_ns <= q0_s AFTER 4 ns;
q1_ns <= q1_s AFTER 4 ns;
END IF;
END PROCESS mux;
END beh;
Testbench
LIBRARY ieee;
ENTITY test_bench IS
END test_bench;
ARCHITECTURE reg2_test OF test_bench IS
COMPONENT reg2
PORT (
clk : IN std_logic;
d0 : IN std_logic;
d1 : IN std_logic;
load: IN std_logic;
res : IN std_logic;
q0 : OUT std_logic;
q1 : OUT std_logic
END COMPONENT;
-- stimulus signale
SIGNAL s_clk : std_logic := '0';
SIGNAL s_d0 : std_logic := '0';
SIGNAL s_d1 : std_logic := '0';
SIGNAL s_load : std_logic := '0';
SIGNAL s_res : std_logic := '0';
-- response signale
SIGNAL q0_r : std_logic;
SIGNAL q1_r : std_logic;
-- Verschaltung des DUV mit den Stimulus/Response signalen
BEGIN
u1 : reg2
PORT MAP ( clk => s_clk, d0 => s_d0, d1 => s_d1, load => s_load,
res => s_res, q0 => q0_r , q1 => q1_r);
-- Taktgenerator ( 100MHz )
s_clk <= NOT s_clk AFTER 5 ns;
-- Stimuli
stim : PROCESS
BEGIN
s_res <= '1', '0' AFTER 20 ns;
s_d0 <= '1' AFTER 20 ns;
s_load <= '1' AFTER 40 ns;
WAIT;
END PROCESS stim;
-- Abbruch der Simulation
stop_sim: PROCESS
BEGIN
WAIT FOR 100 ns;
ASSERT false REPORT "simulation stopped" SEVERITY failure;
END PROCESS stop_sim;
END reg2_test;
