Maybe it is really easy question but I spent two hours looking for solution and information in the internet and still I can't push it to work.
I need to do arithmetic left shift operation. I used standard SLA operator.
ModelSim during compilation shows an error:
Blockquote ** Error: (vcom-1581) No feasible entries for infix operator 'sla'. ** Error: Bad right hand side (infix expression) in variable assignment.
My code
constant Vlsb : std_logic_vector(47 downto 0) := x"00002710CB29";
i_data      : in std_logic_vector(15 downto 0);
process(i_clk) is
    variable data : std_logic_vector(47 downto 0);
begin
    if(i_rst_asyn = '0') then
        data := (others => '0');
    else
        if(rising_edge(i_clk)) then
            if(i_rst_syn = '1') then
            else
                data(15 downto 0) := i_data;
                data := data sla 31; -- ERROR LINE
                data := std_logic_vector(signed(data) / signed(Vlsb));
            end if;
        end if;
    end if;
    o_data <= data;
end process;
Could sombody tell me what I am doing wrong, please.
Add- I am using std_logic_1164 and numeric_std library in this module.
  • \$\begingroup\$ There is a good answer on this topic here stackoverflow.com/a/9035788/4090959. Note that the 'Update' is important. \$\endgroup\$
    – scary_jeff
    Commented Jul 18, 2017 at 9:35
  • \$\begingroup\$ Simply declare your variable of a type for which there is a declaration of sla; alternatively, nothing stops you writing your own sla for the type you have chosen. \$\endgroup\$
    – user16324
    Commented Jul 18, 2017 at 14:46
To use the operators sla or sll , etc ... you need to use the bit_vector type and not the std_logic_vector one.
That's why I don't advise anyone to use these kind of shift operators but rather instantiate a for loop like the following:
FOR i IN 0 TO N - 1 LOOP
    data := data(14 DOWNTO 0) & data(0);
END LOOP;
  • \$\begingroup\$ What exactly does the loop do in this example? \$\endgroup\$
    – user16324
    Commented Jul 18, 2017 at 11:55
  • \$\begingroup\$ It shifts data from N bits to the left in one clock cycle (and pad with '1'). That's what @e2p is looking for I guess \$\endgroup\$
    – A. Kieffer
    Commented Jul 18, 2017 at 12:22
    \$\begingroup\$ You mean it's a way of obfuscating data := data(15-n downto 0) & (n-1 downto 0 => '1');? Also, where does padding with '1' come from? \$\endgroup\$
    – user16324
    Commented Jul 18, 2017 at 12:54
  • \$\begingroup\$ why '1'? , arithmetic left shifting put '0' on empty position \$\endgroup\$
    – e2p
    Commented Jul 18, 2017 at 14:12
    \$\begingroup\$ Regarding the padding, I think you are confusing sla with sign extension in sra on negative numbers. \$\endgroup\$
    – user16324
    Commented Jul 18, 2017 at 14:44
