I have searched some information about the diference between Signals and Routed on the PCB Tab in Altium, and I understand it, but, when you have to do a length matching, Which is the best option? The diference is not stable (2 mils, 3 mils, it depends of the trace I have done).
Thank you so much!
Edit adding an example with huge difference between routed an signal.
I don't understand that 30 mils difference.
EDIT 2: Checking the vias, there is a lot of length trace on them, and invisible traces. That was the problem. Thank you so much!
