In textbook treatments, one has that the source and drain of a MOSFET are completely symmetrical and therefore interchangeable -- the distinction is only made by which is at a higher voltage in the circuit in which the MOSFET is used. Gray and Meyer (Analysis and Design of Analog Integrated Circuits, 5e) however note that "In practice, the symmetry is good but not perfect."
Why is the symmetry not perfect? Is it the case that fab processes actually design drain and source diffusions slightly differently (for, say, the unit transistor in a given process) or is the "in practice" caveat simply to note that drains will be connected to, for example, an output node with lots of other connections thereto whereas a source might not be. That is, is the "in practice" distinction between source and drain intrinsic to the process or simply about how we electrically connect them in most circuit designs?
Generally, transistors used in logic circuits do have symmetrical source and drain characteristics. This includes the basic design and layout of the device, halo doping effects, VT adjusts and strain effects.
Devices used for analog circuits may, and all high voltage devices have asymmetrical source and drain structures. This is because the source will not be biased more than a small voltage (say < 5 V) above the bulk, and VGS will not exceed a similar small value. However the drain may need to withstand very high voltages (to 1000 V) -- therefore it needs a lighter doping than the source (and portions of it need to be spaced further aways from the gate structure).
For HV devices, this has the effect of adding a significant resistance in series with the drain (which is not present in the source side). This alone gives a different DC characteristic to the device. The additional capacitance associated with the drain gives a different AC characteristic.
  • \$\begingroup\$ Beautiful, thanks so much for this very nice answer! A quick question though I've accepted. You say "...therefore it needs a lighter doping than the source". Why does this follow from needing to withstand higher voltages? Do avalanche or band-to-band tunneling effects at the drain-body pn junction worsen with drain doping? I would have thought that the lower-doped body would have been much more relevant than the drain doping. \$\endgroup\$
    – EE18
    Commented Jan 14 at 14:49
  • \$\begingroup\$ In general PN junctions with a higher breakdown voltage require lighter doping. This comes from the fact that the depletion region width depends (inversely) on the doping, and the peak electric field (which limits the breakdown) depends on the applied voltage across this depletion region. \$\endgroup\$
    – jp314
    Commented Jan 14 at 17:59
  • \$\begingroup\$ This could be accommodated partially by having a lighter-doped body, but HV MOSFETs also require a means of protecting the Gate-Drain overlap oxide from breaking down (this oxide can only withstand a few V). By making the drain lightly doped, when HV is applied, the (reversed biased) depletion region extends towards the source, thus 'shielding' the gate oxide from the high voltage. \$\endgroup\$
    – jp314
    Commented Jan 14 at 18:02
  • \$\begingroup\$ Understood, thank you! In your last sentence did you mean "drain" rather than "source" by the way? \$\endgroup\$
    – EE18
    Commented Jan 14 at 20:01
  • \$\begingroup\$ No - the drain-body depletion region extends from the drain towards the source as the drain-body (reverse) bias voltage increases. \$\endgroup\$
    – jp314
    Commented Jan 14 at 21:21
After doing some reading, it seems we can make the following observations which answer the question:
  1. There are differences associated with the channel at either end of the MOSFET.
Strain: This technique involves altering the crystal lattice structure of the silicon in the channel region to improve carrier mobility. The application of strain can be different near the source and drain regions, leading to asymmetrical electrical characteristics. For instance, tensile strain might be applied near the drain to enhance electron mobility in nMOS devices, which can make the drain region's electrical properties slightly different from the source. Incidentally, there are various reasons you might introduce more strain at the drain end than at the source end, but whatever these reasons they lead to a difference between the source and drain.
Halo Doping: Halo or pocket doping involves implanting impurities in the substrate around the source and drain regions to control short channel effects like threshold voltage roll-off and punch-through. The concentration and distribution of these dopants can differ between the source and drain, leading to asymmetries. For example, heavier doping near the drain side can be used to manage hot carrier effects, which introduces a difference between the source and drain.
  1. There is another category of differences associated with geometry and layout of the diffusions.
Physical Dimensions: The actual physical dimensions of the source and drain regions can be intentionally varied. For example, in some power MOSFET designs, the drain region is made larger to handle the higher voltage drop, while the source is optimized for better on-state resistance.
Parasitic Elements: The layout of the MOSFET on the chip can lead to different parasitic capacitances and resistances at the source and drain. For example, if the drain is located farther from the gate than the source due to layout constraints, this can lead to higher drain-gate capacitance. (This point was referenced in my question but it is not really intrinsic to device operation. That is, if we "flipped" the device around in an otherwise symmetrical textbook MOSFET we would get the same operation.)
  • \$\begingroup\$ "in some power MOSFET designs"--what you refer to here is mostly vertical MOSFETs (aka VDMOS). Lateral devices can have such enlarged drains, but they are rarely used as power devices outside of RF applications. \$\endgroup\$
    – Hearth
    Commented Jan 13 at 20:06
  • \$\begingroup\$ Thank you for the clarification! Very helpful for me. @Hearth \$\endgroup\$
    – EE18
    Commented Jan 13 at 21:54
