(I am learning the digital circuit design. Excuse me if this is naive question.)
From the Wikipedia, I found the following diagram about SIPO shift register:
As I understand, this shift register is made of DFF (D Flip-Flop). DFF is triggered at the rising edge of the clock period. So for each rising edge of the Clock
signal, the data from the Data In
will propagate through one stage of DFF.
My question is, since the Clock
is shared by all the DFFs, when the rising edge arrives, all the 4 DFFs must be in triggered/transparent state. So what ensures that the data propagate through only 1
stage of DFF rather than 2 or more stages?
Let's say:
Td
is the internal delay for 1 DFF stage to load data from D to Q.Tr
is the lasting time of the clock rising edge. See below pic.
I think to limit the propagation to 1 stage, it has to be:
Td < Tr < Td*2
Am I correct?
But in the link above, it says:
In this configuration, each flip-flop is edge triggered. The initial flip-flop operates at the given clock frequency. Each subsequent flip-flop halves the frequency of its predecessor, which doubles its duty cycle. As a result, it takes twice as long for the rising/falling edge to trigger each subsequent flip-flop; this staggers the serial input in the time domain, leading to parallel output.
It makes me confused about a few things.
- What does
mean? - How could a DFF be characterized with a frequency?
- Doesn't a DFF only work at the rising edge of the clock and in general don't care whatever frequency the clock is at?
- And how could frequency be related to duty cycle? Frequency is related to period while duty cycle just means the percentage of one period in which a signal or system is active. I see no relation between frequency and duty cycle.
ADD 1
As Neil_UK said in his reply below, the above wiki quotation is plain wrong. And he has fixed the wiki page.
As EM Fields said in his reply below,
...nothing more can happen until the next rising edge of the clock, since the clock edge that did the work has already died...
Strictly speaking, there's no ideally vertical rising edge. There should be some Tr
as shown in above illustration. I guess to limit the propagation of signal through DFF stages, the rising edge must last long enough for the signal to propagate through one stage and short enough for the signal not to propagate through to the next stage.
I just think this kind of control is too tricky/delicate to be true. But if it is true, how is it achieved? (I just placed a bounty for this question.)
Tr
, I think all DFFs should be transparent to input. That's why I think there's a need to control how far the signal can propagate. \$\endgroup\$
