CORRECTION
The Mealy machine stores each state with 3 sequentially stored bits plus INPUT.
Please revise my Moore Machine to a Mealy Machine by only using 3 bits stored and 1 present state input = D
(Just for Dave who was right but he is still trying to make his simple algorithm which has a more complex schematic)
Both types can produce output glitches if output is not re-sync'd with a register from transition delays of 0>1 and 1>0 on different gate inputs.
The Moore machine does not use present input as mine does below, which is easily corrected but requires an extra flip flop to convert random data into synchronized clocked data as the present state input, so result is the same!!
Note the FF at the output is necessary to prevent Race Conditions or Metastable glitches.
end edit
The function in a couple ways.
Dave's way with a 3 bit SIPO register, 3 bit adder and comparator for sum=010 for IN=0 and sum=001 for IN=1 and Out=0 for all else.
I prefer the SIPO to be the sequence memory
So the simple solution for me is to disable the output with 3 input NAND and 4 input OR for the count of all 1's and all 0's. (edit.. curses the iPad auto spell corrector)
Solution
f(D,clk)= {XNOR & OR & NAND} AND all outputs {Qa,Qb,Qc,Qd}
- (ignore numbered Q's for LSB 1st in simulator)
The reason I like Falstad simulator is it only took 10 minutes to use the builtin white noise generator (ANT.enna) and -6dB/oct to convert to pink (-3dB/oct) then brown noise is clipped with the HPF self biased inverter then choose small Options Small grid and select the SIPO and Gates and edit to 4 input.
Note the scope traces with green arrows.
- The 1st shows the NAND output low with >=4 consecutive 1's.
- The 2nd arrow shows the OR output low with >=4 consecutive 0's.
- THese are the only times when the XOR output has to be disabled (AND) so that odd number of 1's = 1 or an even number of 1's =0 so an inverter is applied to make it XNOR.
In case you have a hard time seeing 1's and 0's I made a simple R ladder to count 1's so you see a (nonlinear) 5 level with two 1's being the 3rd level.
( I'm painting but this was too much fun to show a few tricks)
This gating causes glitches so the output must be resampled by same CLK and D FF.
counts up and0
counts down. The counter has a range of0..4
, that means you have to implement a saturation counter (4 + 1 = 4
). So in total you have 5 states for0,1,2,3,4
and 10 transitions (1 input * 2 input states * 5 states). \$\endgroup\$
