If IIUC: contamination delay (\$t_{cd}\$) is the time where the signal level on the output of a component starts to change in response to a change on the component's input, while the propagation delay (\$t_{pd}\$) is where this signal level change on the output stabilizes (i.e. becomes valid). Furthermore \$t_{cd,min}\$ of a component must be bigger than the maximum hold time of a subsequent component connected to the first component's output.
While all component specifications I found provide \$t_{pd,max}\$ none of them provided \$t_{cd,min}\$. What is the reason for this? Can I assume in this case that \$t_{cd,min} = t_{pd,max}\$ ?
