I have a round surface of 1.5 meters in diameter that contains many electronics. What I would like to do is distribute a 10MHz 3.3V clock signal from Teensy 4.0 across the table for 200 ADCs to access it. The ADCs are placed evenly across the whole round surface. It sounds crazy, I know, but there are many limitations to this system that make me consider it. What would be good options for creating such a clock grid?
Some background information: The issue started with the fact that I need the 200 ADCs to work synchronously by using an external clock (preferably, from the Teensy 4.0) instead of their internal clock. I tried to supply this clock signal to one of the ADCs at a distance of 1.5m and the signal was very ugly and ringing because of the inductance and capacitance of the wire. Also, I saw a reflection of the clock signal because the impedances are not matched, hence, the 10MHz wire acts as a transmission line. For this measurement, I used a regular ribbon wire. I learned that it would be much better to use a shielded cable, such as CAT5 or CAT5E. However, the space is very limited for this surface, and I also need to supply 200 modules with a sufficient clock signal. I looked into the option to use M-LVDS (Multidrop), however, I have concerns that there might be better-suited options to look into that I have not thought of.
Any comments and ideas would be much appreciated. Please let me know if I should provide any additional information.
