I need to create a lot of BRAM blocks in my (Altera) design. Each one has unique memory contents, determined a priori using an algorithm.
Before, I was setting a parameter for each BRAM cell to read from a .MIF, but this caused my compilation time to take forever.
Another approach I concocted was to allow "dynamic" population of the memory; the host controller would be able to send symbols to the FPGA to populate its BRAM blocks with. This is a little more complicated than I would like.
I was hoping there was a way to initialize BRAMs with a literal. Each block is only 1 bit x 256, so the resulting HDL code wouldn't even look that ghastly.
Does anyone know how to do this with Altera's BRAM IP, or perhaps even Xilinx's?
UPDATE 8/31/2016:
Hey guys, I actually found a very easy almost "turn key" solution to BRAM initialization on Altera. In Quartus, there are built-in VHDL and Verilog templates which can automatically infer BRAM. These templates have memory initialization utilities built-in which the user can modify to populate with whatever data they want (such as a bit vector from a generic). See this Quartus help page.
