I want to execute 2 modules, one after another using one flag signal
What changes do I have to do in code below to the modules. I have used delay_4 and multiply.
module iir_model(yout,temp1,win,clk);
  input  [3:0] win;
  output [3:0] yout;
  wire   [3:0] yout;
  input        clk;
  output [3:0] temp1;
  wire   [3:0] temp1;
  delay_4      a1(temp1,win,clk);
  multiply_4  (yout,win,temp1);
endmodule
delay_4:
module delay_4(data_out,data_in,clk);
  input [3:0] data_in;
  input clk;
  output [3:0] data_out;
  reg [3:0] data_out;
  reg [2:0] counter=4'b000;
  reg [3:0] temp;
  reg carry;
  integer i=0;
  always @(posedge clk)
  begin
    i=i+1;
    if(i==1)
      temp=data_in;
    if(i>1)
    begin
      if(counter!=4'b100)
      begin
        carry=temp[0];
        temp=temp>>1'b1;
        temp[3]=carry;
        $monitor ($time," clk=%b,  counter=%b ,temp=%b ,carry=%b,data_out=%b",clk, counter,temp,carry,data_out);
        counter=counter+1;
      end
      data_out=(temp==data_in)?temp:4'b0000;
    end
  end
endmodule
multiply_4:
module multiply_4(z,x,y);
  input  [3:0] x,y;
  output [7:0] z;
  reg    [7:0] t;
  reg    [7:0] z;
  integer i,j;
  always @ (x or y)
  begin
    z = 8'b0;
    for(i = 0; i < 4 ; i = i + 1)
    begin
      t = 8'b0;
      if(y[i])
      begin
        t[i]   = x[0];
        t[i+1] = x[1];
        t[i+2] = x[2];
        t[i+3] = x[3];
      end
      z = z + t;
    end
  end
endmodule
  • \$\begingroup\$ In Verilog, everything in 'always' blocks executes all the time, as triggered by its '@' conditions. So multiply_4 gives you multiplied result whenever its input changes. Note that it's probably not synthesizable. \$\endgroup\$
    – pjc50
    Commented Mar 13, 2013 at 11:08
In Verilog, things don't execute one after the other, they execute in parallel. If you want to feed the results of one module into the inputs of another (ie a pipeline) then you just create the wires and connect them to the appropriate inputs and outputs.
I'm not even a reasonable Verilogger, so I can't see immediately what your problem is, but it might help to use named associated rather than positional association to do the wiring as its easier to see mistakes in port ordering that way.
  • \$\begingroup\$ thanks for you answer i will try using wire and if i stuck somewhere i will tell you thanks once again \$\endgroup\$ Commented Mar 13, 2013 at 14:07
Some pointers to help you refactor code to spot the issues faster.
When posting code examples it is often nice to keep them to a minimum, and in practice less typing for you.
I would refactor the following:
  input clk;
  reg [3:0] data_out;
to:
module delay_4(
  input      [3:0] data_in,
  input            clk,
  output reg [3:0] data_out,
If you do not do this then at least keep the port definitions in the same order, as the original port list, otherwise it becomes quite confusing to read, help us to help you.
I would also always have a reset that went along with the clock. I instantiate flip-flops like :
always @(posedge clk or negedge reset_n) begin
  if(~reset_n) begin
    //reset
  end
  else begin
    //<= next_value
  end
end
In always @(posedge clk) block you should generally be using the non-blocking assignment <= other wise you may end up with simulator to hardware mismatches, which are quite hard to debug.
As @Martin Thompson has said named connections help aid debug, add comments showing direction for extra points.
would become:
NB: multiply_4 is missing an instantiation name
delay_4      a1(
  .data_out(temp1), //output  [3:0]
  .data_in (win  ), //input   [3:0]
  .clk     (clk  )  //input
multiply_4  multiply_4_0 (
  .z       (yout ), //output [7:0]
  .x       (win  ), //input  [3:0]
  .y       (temp1)  //input  [3:0]
