I'm new to FPGAs and I'm trying to determine how an FPGA determines whether to register an input as a logic 0 or 1. The FPGA I am using is the Artix 7 and I would like to connect it to a function generator giving a square wave that toggles between 0 and 3.3 V.
In my constraints file I set the pins where I am connecting the function generator to the LVCMOS33 IO standard. Do I need to set the logic threshold as well or is it automatically set at 1.65 V since I have the standard at 3.3 V?
Here is the FPGAs data sheet for switching characteristics, but I haven't found any threshold information.
9
The logic levels are shown in Table 8 of your referenced datasheet.
  • \$\begingroup\$ I wonder how they make the hardware to support selectable I/O voltages \$\endgroup\$ Commented Oct 11, 2022 at 11:28
Although the above answer shows the DC voltage ranges for the input and output, the FPGA determines if the input should be a logic 1 or 0 by comparing it to a voltage reference (VREF). This depends on the FPGA you are using but for the Artix 7 in Vivado you can drag the voltage bank that your pins are assigned to the correct Internal VREF. In the following picture I assigned Bank 34 to a 0.9V reference. Anything above 0.9V is a logic 1 and anything below is a 0.
You can also define the voltage reference in your XDC constraints file using the following TCL command: set_property INTERNAL_VREF 0.9 [get_iobanks 34].
Read more about how to set internal voltage references and the benefits of doing so on Xilinx's website here
