I'm software developer in a small shop where there's only been one EE guy responsible for a series of FPGA designs spanning a decade, almost all of which target the Spartan line, specifically the XC3S5000.
I'm looking for the community's opinion on some of the EE guy's assertions which I find hard to believe:
1.) Many builds must be created and tested (without changing the input files) because a particular binary often fails testing due to "timing issues." (verbatim)
Me: Is frequent failure of an FPGA design expected and this incredibly slow process considered normal? I can't imagine repeatedly compiling the same traditional software development language and hoping the output will be right *this time*. The HDL seems underspecified if this is the case.
2.) Because the creation process is subject to "random" algorithms (I assume this is placement and routing) it is "very hard" to recreate the binary from just the input HDL.
Me: Surely there is an initial seed provided to this pseudo-random algorithm which can be queried after a successful build? The exact good binary could then be recreated using the seed later. This seed could optionally be checked in to source control.
3.) Because the Xilinx-provided tools may change (be upgraded, etc.) even if an exact recreation is possible from a known good seed and the old tools, a new set of tools may create a binary which fails testing. EE guy doesn't see any use in investigating how to find the random seed used for a build, and how to provide it to a rebuild.
Me: How likely is a build to break upon introduction of new tools?
4.) The binary build process disallows any post-build manipulation of the bytes of the binary due to checksumming and the inability to write to a known offset into this binary.
Me: You can't embed information into an existing binary?
5.) He insists on checking in both the final product and NGC files.
Me: Is there ever a reason to store NGC files?
Notes:
*FPGA binaries will eventually be stored in a different place, but definitely not in a text-centric version control system.
*We use a fragile version scheme to query what FPGA is currently running in our system. It is useful for software to work around hardware bugs by checking if the FPGA is of a certain version. We can read both a monotonically increasing 16-bit number and a build date from the FPGA, but these numbers don't sync directly with the version control system in which the binary is checked in.
*I've looked over the following questions already: What files/directories are needed to recreate a Xilinx PlanAhead project?
