I've been reading about how asynchronous CPUs work, but they always seem to involve some complicated way of communication. Wikipedia talks about a two-way and four-way handshake. I found a pdf from iosrjournals.org that talks about communicating Requests, Acks, and Data either in 2-phase bundles or 4-phase bundles.
I don't understand why any of this is necessary. Why don't you just use a single bit on a dedicated line that is 0 until the operation is complete? Then it becomes a 1. Then the accumulator at the end of the ALU will know the "final answer" is finished and it can switch the buffer from read to write, outputting it on some other bus.
So of course it begs the question as to how the ALU will know when its done. I'm not exactly sure how to do that, but the simplest way to do it would be to just set it to 1 immediately and then make sure the propagation delay is long enough such that the worst case operands finish in time. But this is a unique trace for each operand the ALU is capable of. It's not like a clock signal that has to be long enough for the worse case of any ALU operation.
Is there something fundamentally wrong with this idea? And if so, isn't there some easier way for the logic to figure out when it's done and then signal completion using a single bit, zero for not complete, 1 for complete?
Note, everything I've read so far seems to indicate 2 or 4 lines for dedicated communication in asynchronous things. So I don't think that a single "completion bit" on a dedicated line would be too expensive or you can't find room for it.
